Objects in Workspace Sharing
Uthayan
How to share data in Workspace with others without checkin into commonspace, thereby version increase not occurs i.e Iteration remains to be same?
Rgds,
-Uthayan.
Export the workspace content as a .pws (portable workspace) file and share it with the intended recepient. PWS export option can be accessed in Pro/ENGINEER via Tools # Server Manager # Workspace # Export
Thanks Dinesh...
Can this be possible for third part application (UG/Solidworks)...As I dont see an option of Export.
Let me know your views on the above scenario..
Rgds,
-Uthayan
I haven't explored 3rd party WGM much but I assume there should be similar option available there as well in WGM for UG/SW.
