55 Replies Latest reply: Aug 28, 2015 7:07 AM by FrankS.Schiavone RSS
    So, why doesn't "update" actually WORK?
    FrankS.Schiavone Platinum
      I have "dm_overwrite_contents_on_update" set to "yes", and an overwrite in Intralink worked just fine, every time......yet now in W/C update doesn't actually do anything? Huh?
        • Re: So, why doesn't "update" actually WORK?
          We ended up doing an "Add to Workspace", and choosing NOT to reuse the file did the trick. However, this is still puzzling, why doesn't Update work?
            ptc-4108908 Copper
            We experienced the same problem in Windchill 10 now. But for 9.1 update was working. Hope this can be corrected.
              mtoreskog Copper
              Hi
              The definition of the Update action in Windchill differs from Pro/INTRALINK. In Windchill you use the Update action in order to update out-of-date objects, i.e. retrieve a later version of an object to the workspace from commonspace. E.g. you have version 1.4 (A.4) in the workspace and there's a 1.5 (A.5) version in commonspace. The Update action will overwrite the 1.4 version with the 1.5 version. With the dm_overwrite_contents_on_update preference you can set the default behaviour when you have modified the 1.4 version using continue. If it is set to Yes you will overwrite the modification made to the 1.4 version. If it is set to No you will keep your changes but they will have been made to the 1.5 version. E.g if the 1.4 version is a simple extrude. You have modified the 1.4 version using continue, adding a hole.The 1.5 version contains the simple extrude and a round. If you use Update and have the dm_overwrite_contents_on_update preference set to No you would have the 1.5 version in the workspace with the extrude and the hole without the round (i.e. you have overwitten whats in the commonspace). If you check it out and check it in the 1.5 version would be the extrude+hole and not the extrude+round.
              The action to overwrite modified content in the workspace (made by you) is Add (read Add to workspace). E.g. you have the 1.4 version in the workspace and you have made modifications to it using continue. You can deselect the Reuse content in target workspace or go to the Advanced tab, select the objects and click Download. I would suggest that you go to the Advanced tab so that you can decide what objects to overwrite and what objects to reuse. E.g. if you use the Add action on an assembly the dependencies set to required will overwrite all modifications made to all parts if you deselect the Reuse content in target workspace check box.
              Hope this helps.
              /Martin
              The
                  Thanks, that's helpful, but still too complicated. Still not sure I follow it actually. Honestly, I think I'll just avoid using the command, and stick to "add to workspace". The Intralink definition is so much better and simpler. You update, and it changes whatever was in your Workspace to be what's in commonspace. Simple, easy to understand. I don't see the need to completely refine terms we were all familiar with to completely reverse what they used to do. Think what would happen if the meaning of stoplight colors was reversed.
                    mmontgomery-2 Copper
                    Martin,
                    In Windchill (pdm essentials), we've been trying to change the default setting to download the latest from the commonspace however whenever I do an update it always defaults to reuse, we've set the reuse option to no as seen below:
                    I've done this at the coorg and wcadmin level and it persists with the default of reuse:
                    Is there another setting that is overriding this?
                    We've seen some instances where people use the "continue" option instead of "checkout" and then make some changes and save them in their workspace, they then do an update and think that all the latest and greatest has been downloaded and theyre good to go. They then check out/check in and the changes they made before checking out are then checked in. this has led to lost work and wasted time. If we could either remove the "continue" option and force a "checkout" or delete "locally modified" content, we'd be a lot better off.
                    Any help is greatly appreciated.
                        mdebower PTC Community Champion
                        Marc, (Glad to see you spell it correctly....)
                        Try selecting the objects and then using the Add to Workspace command, there should be an icon for it in the icon bar. You will need to uncheck the "Reuse Content From Target Workspace" option.
                        That should download a fresh copy of the objects to the workspace, replacing the modified ones.
                        Confusing as he!! I know, not sure who that made sense to...
                        -marc
                            -EDIT-
                            Marc,
                            Thanks for the reply, it appears that it just took a while for my changes to take affect. This morning it was no longer an option to reuse content during an update
                            Marc
                                Unfortunately my changes did not *entirely* take affect - if i hit update in a Firefox based windchill session, there is no option to reuse content and it downloads the latest from the server commonspace. This is what I want. However, if I hit update in the embedded browser within Creo, the default action is to still reuse content - I have to manually tell it to download most recent from the server. This is NOT what I want.
                                While I understand the difference and implications and I can probably remember to use the correct settings, I cant expect that all the other CAD Authors using the software will. Does anyone know why the embedded Creo browser would act any differently than a Firefox session of Windchill?
                                Also, I did place the suggested parameter into my config file dm_overwrite_contents_on_update set as YES and that made it so that when I update an assembly from within Creo (not a browser) it does download latest from the commonspace. Thanks for that Martin.
                                Any suggestions to fix this would be much appreciated, I know there's a lot of issues with Windchill but I'd like to focus on fixing the issues.
                                Marc
                          ptc-4108908 Copper
                          Frank,
                          When the update applet appears, click on the download icon to use the file in the commonspace.
                            hammerhead Copper
                            Frank,
                            Why would someone decide to redefine the meaning of "update" to something else? Update doesn't mean update anymore. What were they thinking? Someday I'm going to meet one of these programmers and maybe we'll be able to come to an understanding. I have never seen a program so unintuitive.
                              We are now almost done with a project here that used a top-down assembly (skeleton), and have had TONS of lost work and problems because Windburn refuses to actually update the parts referencing the assembly, or worse, updating the skeleton that drives everything. This is totally absurd. We've found here that sometimes it's more robust to do an update, not in windburn, but while in the part or assembly. Of course, sometimes even THIS does not work, and worse, doesn't show in in the workspace that it's out of date, leading to HUGE problems. I've found that the ONLY reliable way to make sure you have the latest files is to DELETE ALL the files in question, then re-add them to the Workspace again, unchecking the re-use box.
                              This is truly pathetic. I should send PTC a bill for all the man-hours we've wasted on this garbage.
                              I've said it before and I'll say it again: This is, by far, the WORST software I've ever used, anywhere, in almost 30 years of using software. That it's supposed to play such an important role makes it all the more frustrating.
                                  LoriSood PTC Employee
                                  Hi Frank,
                                  If you are seeing inconsistent behavior with the Update and Add to Workspace functionality or with the config.pro options used in conjunction with Windchill then that should be investigated by PTC. Were cases ever opened for this?
                                  In general, Update should update out-of-date objects (i.e. there is a newer version on the server because someone else checked it in while the user had it in their workspace). Add to Workspace should let you bring in other non-out-of-date files, where you can either reuse the content already in the workspace or overwrite it. Workspace synchronize will update metadata changes (lifecycles, etc.) from the server.
                                  If that's not happening then it would be good to investigate the use cases you are seeing to figure out why.
                                      dschenken PTC Community Champion
                                      Windchill works great if you are a content consumer. A content consumer can freely delete workspaces as there is nothing they need in them and create new ones to load the currently desired information.
                                      In a collaborative content creation environment, Windchill is frequently a hassle.
                                      While I understand there needs to be a lot of redesign to do so, content creators need a system that pushes changes, not waiting for participants to pull them. That is, if I'm working on a complicated assembly and someone else on the team checks in a new version of a part that's in that assembly, then Windchill should push that update automatically to all the Workspaces that item is in and the active Workspace should flag Creo that a new version of the part should be loaded into session.
                                      This means part files and meta-data.
                                      Flagging is required for those working on As-Stored data, but that could also be handled with a "Don't Update" flag on the Workspace.
                                      Instead, in a team environment, Windchill withholds new information unless specifically requested, leaving a pie-in-the-face / rug pulling situation. This is especially true for family table management where Windchill won't automatically gather (at least through 9.x) all the members of a table for Update that are in the Workspace. Instead it's like HAL 9000, "I'm sorry Dave, I can't do that," followed by a lengthy separate search for all the individual family table members because Windchill isn't programmed to update the instances when the generic alone is chosen.
                                      Another place for confusion is where an unwanted change is made.
                                      The choices are Update and Add. In Intralink, where a lot of people started, Update would overwrite the Workspace version with the Commonspace version, discarding unwanted changes. This is not the same behaviour in Windchill, causing no end of problems for people during their learning transition period.
                                      There should be a clearly defined operation, like "Restore" that would take modified items and restore them with the Commonspace configuration. Software developers may love overloading operators, but humans don't do so well and benefit from clear differences in descriptors and vocabulary that doesn't change meaning.
                                          I agree David. I've made the "HAL 9000" reference several times in the past as well.
                                          Oh, and here's another one: Often, we have new users that roll the rev beyond (sometimes FAR bayond) what it should be on accident. If the part should be at rev B.12, but has been advanced to C.1, as a medium-level admin, I should be able to roll that C.1 rev back to B.13. NOT being able to is a crock. I understand that not even the top admin can do it. That is a huge limitation.
                                          As I mentioned Lori, sometimes it does, sometimes it SAYS it does, but doesn't.....with no warning but instead a line that says "All objects up to date"....which is a lie. Thankfully for our major project, I KNEW what geometry changed, and when I didn't see it appear on someone's system, I deleted the file and re-added it to their Workspace. This is inexcusable and puts us in an untenable position. Since I control the skeleton I know what changes have been made, my users don't, so when update does NOT work (more often than not) there's the chance for big trouble.
                                          I've filled out tickets, and the result is......nothing. In all the tickets I've submitted, there has been no resolution that I haven't found myself, or simply worked around, or just dealt with. Honestly, I'd recommend my company dump maintenance completely and just buy new seats every couple years....it'd be cheaper and less hassle.
                                          My main problem with Windburn? The fact that Intralink, which we HAD, was so much better, but corporate greed led them to strong-arm people by making new files incompatible with Intralink, so we HAD to switch. I resent that attitude and those business practices.
                                          I've been a loyal power user for over 18 years now, but things like this seriously make me want to switch to, and RECOMMEND to my company, a switch to Solidworks.
                                              Frank,
                                              As I mentioned earlier, if you're seeing inconsistent behavior it should be investigated by PTC via a techincal support case, and the functionality regarding update should be the same across the board (i.e. only update objects marked as out-of-date). I tried looking up your past cases, but didn't see any in the list that looked to be related to update functionality. Do you recall case number(s) for this? Were reasons provided for the behavior you were seeing?
                                                  SteveShaw PTC Employee
                                                  Frank,
                                                  Lori is correct. If there are specific scenarios or data sets that you are finding where the Update action is not responding as expected cases need to be filed with technical support so that these may be evaluated and addressed by PTC R&D.
                                                  Steve
                                                      I've been on a very rush project for some time now. While I've tried to help PTC in the past using my own free time, it didn't seem to help and it did nothing for me. "IF" I have some spare time on this project and run into the issue again, maybe I can file a case number. To date, I've had almost zero luck with any of that over the years, so you must excuse me for being somewhat reluctant to do beta testing for PTC.
                                                      I'll be blunt, I hate the product, and so does almost everyone else I've talked to, at 3 different companies and on here. All the more disappointing since I (and many others) really liked Intralink. Tired of having to make excuses for it to the ex-SW Engineers we hire who are constantly complaining about it....for good reason.
                                                          BuddyHudson Silver
                                                          Frank,
                                                          I so feel your pain. I am a long time Pro/E/Creo user since the early 90s, and now I administer a fairly large group of engineers using Creo 2.0, and Windchill 10.1 M020. It has been rough since Windchill came along. PTC offers system and business courses which cover nothing about how to truly manage and troubleshoot the system. I won't even get started on tech calls right now....I am not a JAVA programmer neither am I a DBA both of which seem to be a prerequisite for administering this system. There are some guys in the community who seems to know quite a bit about it, and not sure where they got there training. Just wanted to say that I empathize with you on this issue, and I wish more people would make more noise about it of just sitting back and taking it. My company division, not to mention the whole corporation as a whole pays TONS of money in maintenance, but there is no benefit. I have been trying to work through an upgrade for over 3 months now....still have not succeeded.
                                                          Buddy
                                                              dhermosillo Gold
                                                              @Bryant we have spent into the hundreds of thousands of dollars (not including the maintenance and software) and more than 4 years in getting our Windchill system to work the way we wanted. At first we tried just having CAD admins do it with help from IT, but as you are finding, it is not possible. We quickly found that there is no one at PTC who understands how it works holistically. They can offer support on specific details, but we found we didn't even know what questions to ask.
                                                              Everything requires customization from simply getting correct mass data out of Creo (yes, at this tme it still doesn't do this out of the box) to exporting useable bills of materials. You essentially get a framework and options that do things that companies might need, in a terrible interface, and you have to customize it to do something useful for your company.
                                                              We tried hiring consultants to configure it, but that only got us part way. Finally, we ended up hiring a seasoned Windchill administrator, who previously worked at a well known Windchill integration company. That's when all of the pieces finally fell into place.
                                                              Now we have a fairly robust production system and a stage system to try out upgrades.
                                                              The initial quote we got from PTC to upgrade from Intralink to Windchill was $50K; in reality it is an order of magnitude higher and you'll need to hire at least 1 person dedicated to getting it configured and keeping it running and nothing else. You'll also need other people who can support java, system building, network monitoring, etc. And you need the entire company to be dedicated to using it and working out the bugs. It also requires that your processes are well defined and you have a clear plan on how you want to use it.
                                                              I would say that customers who want to undertake a move to Windchill should expect to spend half a million dollars, minimum, for a small enterprise.
                                                              If you need help, PTC will only lead you to frustration. Instead, contact the following companies who helped us immensely:
                                                              Fishbowl Solutions
                                                              http://www.fishbowlsolutions.com/index.htm
                                                              Datafrond
                                                              http://www.datafrond.com/
                                                  As this is getting some attention, is there any constructive advice that could be given to my issues I posted in reply above (starting 7 posts from the top, http://communities.ptc.com/message/269138#269138). We're a smaller company starting out with pdm essentials and while we've certainly had our share of pain with windchill, I'd really like to focus on improving our implementation.
                                                  Thanks, Marc
                                                      CeliaLee PTC Employee
                                                      Marc,
                                                      It's difficult to address your issue from your description. If you read again Martin's explanation, Update is to be used when there is a later iteration on the server. Is that always your case? Or is it just that they want to undo the changes that they made in the workspace. In that case Update cannot take a later iteration from the server. As others suggested in this thread, you can use Add to Workspace to get the latest as long as you uncheck the box as Marc Bower suggested.
                                                      I wasn't sure from the thread if you did use Add to Worspace action becuase you keep mentioning update in the embedded browser.
                                                      -Celia
                                                          Celia,
                                                          Thanks for the response. My issue is simple really, Windchill update is acting different in a stand alone browser vs the embedded browser. Did you read my posts leading up to the last? If WC would do the same thing in each browser I'd be less confused.
                                                          I've set the "reuse modified workspace content" option to "no" and in a browser based session of WC it acts as you would expect, it does not allow you to reuse modified content on update - the only option is to download. This is what I want. However, in the embedded Creo browser when I do the same operation the default is to reuse modified content. This is not what I want. Is there any settings that cause the embedded browser to function differently than a standalone browser?
                                                              Marc,
                                                              I wonder if part of the confusion is due to the workspace cache. Because the cache is on the local client's HD, the embedded browser is the only way to see into it. I would recommend using the embedded browser whenever making changes to the workspace.
                                                              The standalone browser can only see the server side of your workspace and not the local side. This has caused issues for people here in the past.
                                                              -marc
        Hi Marc.
        You mentioned earlier that you have "Reuse Modfied Workspace Content" preference set to No under the "Add to Workspace and Check Out" preferences. What context is that set in (e.g. Site, Organization, Product)? If you lock the preference at the Site level in Preference Management does that make any difference? If I perform an Add to Workspace on a modified file in my workspace then it recognizes what I have set for that preference.
        Are you performing an Update or an Add to Workspace? If the former then that preference will not apply. It doesn't look like there is a preference that controls this behavior for Update. It looks like it will always default to Reuse if the files are modified in the workspace when performing this via Creo. The options to reuse, download, or link are not available in the standalone browser because those options don't apply since it doesn't deal with the workspace local cache, and, therefore, the physical Creo files--essentially, the standalone browser handles metadata for CAD Documents. That's why there is a difference in this case depending on where the action is performed.
        mmontgomery Copper
        All,
        Thanks for your comments. I now understand that the settings I changed initially pertain to the "add to workspace" function whereas I wanted to adjust the "update" function. Rookie mistake. I think I've now figured out what I wanted to do. In the version of WC were running (10.2 Essentials), when I update my workspace, all of my locally modified content is uploaded to the server and I can see the changes in workspace status in a standalone browser. After digging a bit more, I found the following setting and changed it to 'Yes':
        Originally, the default in creo embedded browser to update was to REUSE the modified content, noted by the recycle symbol:
        However, after changing "update overwrite local content" to "yes", the default action then changed to download from server, notice the change from recycle symbol to download symbol. This again is in the embedded creo browser after the parameter change:
        Now you can see that download is the default action and there is a yellow triangle next to it, this is a warning message that modified content will be overwritten.
        Note that in both cases, there are toolbar options (highlighted) to change the action to 'download' or 'reuse', all that is changing is the default action on update.
        As I discussed previously, the default standalone browser action is still to download by default which is what I want:
        I'm still testing this so if I find any issues I will post those later on.
        Marc
        HerwigSchwarz Copper
        In 10.2 you are able to upload content, that is not checked out. This is new.
        Since then it is not possible to overwrite locally modified content in the way you described.
        Because updating essentially transfers the file from the server-side workspace to the local workspace-cache. And both are modified...
        So in order to restore the original file in your workspace, you would actually have to delete it there, search it in commonspace and add it back to the workspace again.
        There is room for improvement, I'd say.
        I tried this setting with high hopes......and it did NOTHING.  I'm pretty upset.
        So, since Windburn does NOT work the way it should, the way any reasonable person would expect, and or the way it USED to work in Intralink (a far superior vaulting system), my advice is:     For everything marked as "Out of Date" in your Workspace, DELETE it, and then add it again.  A HUGE waste of time.  That's the ONLY way you can be sure of actually GETTING updated models....instead of the HAL9000 system simply telling you it's all up to date.....and it not be.  A very dangerous situation.
        Caveat emptor....
        Oh, and my company is thinking about implementing this disaster company-wide, and I'm going to advise them to find something else and re-migrate the data to whatever else is an option.
        dnordin Bronze
        Frank,
        The "fix" I listed above was specific to "re-adding" the commonspace version of a model that is locally modified in the users WS, uploaded, but not checked out.  This is specific to 10.2.  I was answering Herwig's questions/issues.
        We've never had any issues with users updating out-of-date (non-latest) models in their WS.  We only run the update command from within the embedded browser in Creo Parametric.
        DN
        I did a couple tests.
        Test 1:
        1.  Changed that setting.
        2.  Modified a model.
        3.  Did an update from within Pro/E - it worked.
        Test 2:
        3.  SAVED that model.
        4.  Did an update from within Pro/E - it did NOT work.
        Test 3:
        4.  Did an update from within Windchill - it did NOT work.
        If that setting was valuable, it would have worked in tests 2 and 3.  I expect users to save their models after significant changes.  Update SHOULD work after a save, as long as a user has not checked-in their model.  This is obviously not the case.  I'd have to say "Update" is a pretty epic FAIL.  Why would PTC make a command that only worked 1/3 the time????
        Like I said, I've told my users to delete files and re-add them.  HUGE time-waster.  I've told management of this limitation as well.  They're not happy either.  All the users HATE it.
        BenLoosli PTC Community Champion
        Do you have save and upload enabled or is just a plain save to your client side workspace?
        I'm not 100% sure.  The Windburn variable "Upload After Native Save" is set to "yes", and from the description, it seems like that covers it.  I'm ok with that action, what I do NOT want is every "Save" doing an automatic "Check In"!
        dnordin Bronze
        Frank,
        Thanks for listing what you did for your tests.  Some comments:
        Definition:  Out-of-date means that the Windchill Version [revision.iteration] in the CS is at a higher level than what you have in your WS.  For example: A.5 in the CS vs. A.4 in your WS.
        NOTE: If you have A.5+ in your WS, this is NOT considered out-of-date by WC as the versions are still the same, only the model content is different in your WS (your working copy).
        Test 1.
        The modified model is in session only, so your WS model is different than what you have in session.  The "update" command within Creo Parametric is going to replace the in session model (which is modified) with the WS copy of the model.  It did NOT replace your in session model with what is in the CS, but rather with the WS model.
        Test 2.
        After you saved the model, the in session model is identical to your WS model.  The update within Creo Parametric will no nothing as the models are not out-of-date.  Are you expecting the "update" command within Creo Parametric to download the CS model and replace your modified model both in your WS and in session?  The update command will only do this if someone else has checked in the same model [Version A.5 in CS], and now your model is out-of-date both in your WS and in session [Version A.4+].
        Test 3.
        After you saved the model, the in session model is identical to your WS model.  The "update" command within the Creo Parametric embedded browser will do nothing as your model (both in the CS and in session) is not considered out-of-date.  (i.e. the WC versions [revision.iteration] are identical between the CS model and your modified version of the model in your WS)  For example: If you downloaded version A.5, your WS version is still A.5 (albeit with a +).  Only the content has been modified, not the WC version.  The update command in the embedded browser will only work if your model is out-of-date which yours is not.
        If your intent is to retrieve the CS copy of a model [Version A.5 in CS] that you have locally modified in your WS [Version A.5+], you need to use the ADD command, not the update command.  There is no "Add" command inside of Creo Parametric.  You need to use ADD from the embedded browser.  The preference I stated in the earlier post will allow you to retrieve the CS copy of the model when you have a locally modified copy that has been saved, uploaded, but not checked out (WC 10.2+).  Once you have "re-added" the CS model to your WS, you can update the model in session as well.
        DN
        ....except that "Add" doesn't seem to work with any consistency either.  I've found that only deleting the offending files, and re-adding them (see my comments about being a HUGE waste of time) seem to work 100%.  THAT, is my issue.  I don't trust this software.  At ALL.  I'm never sure of anything it does.  sigh......
        "Add" does work with consistency if you set the preference that Daniel Nordin has described above, answering my question.
        Funny, I haven't had it work with any consistency.  I'm still going to advise deletion and a re-add as the only way to be sure.  If windburn considers the model with changed geometry the same as the model with the older geometry simply because of a setting or the same "version", then that's simply another reason for me not to trust the software.  I mean, that logic on PTC's part is simply absurd.
        dnordin Bronze
        Frank,
        Regarding your statement: "If windburn considers the model with changed geometry the same as the model with the older geometry simply because of a setting or the same "version", then that's simply another reason for me not to trust the software.  I mean, that logic on PTC's part is simply absurd."
        WC does NOT consider the model in your WS marked with a + the same as the CS copy.  The version [revision.iteration] listed in your WS is showing you what version of the CS model you originally added to your WS, nothing more; it is not an indicator of any local modification to the model.  The "+" in your WS status column (usually titled Modified Status) indicates that you've locally modified the file.  The "Out of Date" status column in your WS is intended to indicate that the CS version you originally added to your WS, whether you've since modified the model or not, is no longer the latest version in the CS, nothing more.  Again, it is not an indicator of any local model modifications.
        Your WS is your private space that contains your working copies of models that no one else can see.  Within that private space, the only indicator you have as to whether you have changed the model from it's original CS copy, is the "+".  Again the version listed in your WS is a reference only to what CS version you added to your WS.  There is no indicator in the table display to tell you how many times you modified and saved your working copy.
        We currently use 5 columns in our default WS display table to show statuses: Modified Status, Local WS Status, General Status, Compare Status, and Out of Date Status.  Depending on the different status combinations, our users have to decide which function/action to use to accomplish the task at hand.  UPDATE will work with some status combinations, while ADD is needed for others.  We created a small help document with a simple matrix of status vs. function/action for the most common situations.  One of the reasons we did this was because of the confusion between the ADD and UPDATE commands coming from the old 3.x days of Pro/Intralink.  Once our users referenced the document a few times, they learned quickly what they need to do based on the status icon combinations in the columns we display.
        If you search the WC help pages for "About Object Status", there are some definitions/explainations of the status columns.
        DN
        TomUminn PTC Community Champion
        Would you have any interest in posting this (or a picture of it) for the benefit of others?
        I've got all those columns too.  It's too much of a pain for me or my users to try and decipher something that should be dead simple.  Most of my users are x-Solidworks guys, and only part-time Windburn users at best.  I can't expect them to have to decipher this maddengly complex and absurd matrix when they shouldn't have to, and even I can;t remember what conditions equal what.  So, mistakes are made, and then I have to listen to them rightfully complain about what a PITA it and/or Pro/E is, and then I have to clean it all up.  So, Delete, and re-add ALWAYS works, though it's a huge time-waster if there are a lot of files.  i much prefer this to mistakes though.
        "Update" should be just that.  When I drag and drop a file in Windows, it does exactly that, no BS.  That's what I expect.  I seem to remember that's exactly how it worked in Intralink, the much superior software they forced us to not be able to use again.
        I appreciate your comments, don't get me wrong, but it reinforces my distrust and hatred of the software, because it seems NOBODY can get it to work effectively.
        BillRyan Silver
        Frank,
        When we first went to Windchill our tried and true process was to remove modifed objects from the workspace as it was the most reliable method!  But, after 6 years we have learned how to efficiently interact with WC.  Here is my proposal and recommendation:
        1) Update - Use Update once per day before the user starts working to find and update objects that other users have changed to ensure they are working with the latest content.  Do not use update when Objects are in Creo Session...if a large assembly, then WC wants to download required dependents of the assembly.  In our case, large assembly = 100,000+ objects.
        2) Add - In Windchill Environment, the goal is to avoid the Add function as much as possible.  We have our collector settings at None for Dependent cad documents on add to workspace.  I have done lots of time testing and found out that it takes less total time when letting Creo open and download the necessary components.  (File -> Open in Creo and type in the assemlby/drawing name without any objects in the workspace VS.  Add required dependents and then open in Creo.)
        3) Check-Out - Train the users to interact with the conflict pop-up in Creo.  Example - Use continue for the family tables that get marked as modified unintentionally, then check-out when an intentional change is planned for.
        4) Check-In - Train the users to check-in from Creo.  We have the collector settings at Required for dependent cad documents. Only the checked out items in the check-in table will be checked in and if necessary you can check-out lower level dependents in the table on the fly if needed...it ignores all the modifed items in the list.  With this logic, you can reduce the time the user goes to the workspace to refresh table, add or remove items. Tthere is obviously a risk to this process....thus due dilligence is required to check-out the items that are intentionally modified.
        5) Remove - The primary reason to use remove is to reduce the objects in cache to get performance back in our environment.  We have found out that deleting a workspace and creating a new one ensures good performance over the long run.
        We are still in WC10.1 and anxious to test the autoupload functionality to the server side workspace when going to WC10.2.  We were not able to utilize it in WC10.1.
        In config.pro you should have dm_upload_objects set to automatic.
        Not sure what the difference is between the Windchill and Creo setttings.
