11 Replies Latest reply: Mar 17, 2013 6:25 AM by VladimirN. RSS
    Comparing Two RV Arrays and Outputting Character Strings
    ptc-5000285 Copper
      So I'm very new to mathcad prime and I'm trying to compare resultant numbers from computing with range variables. I was hoping someone could show me how to figure out what I'm trying to accomplish.
      Example (simplified):
      I've defined two range variables
      A:=220,320..420
      B:=840,640...440
      then applying some math with the RVs
      C(A):=A/2
      D(B):=B/4
      I would then like to compare the first value of C to the three values in D and determine if it is greater than or less then the D value and then output an array with Yes if greater, or No is less than. Then repeat this with the second and third values in C respectively.
      I'm thing something like this...
      i=0
      j=0
      for i=1:3
      for j=1:3
      if C(i)>D(j)
      E(i+j) = "Yes" %I'd like the ouput to be a one dimensional array/vector and not a two dimensional matrix
      else
      E(i+j) = "No"
      end
      end
      The red boxes are the two variables I'd like to compare, and display if alpha is greater than tau in a coulmn matrix/array.
