2 Replies Latest reply: Oct 28, 2009 9:13 AM by DELETEME RSS
    What are you guys doing for library parts?
    Silver
      What are you guys doing for library parts, in particular fasteners? Are you buying the PTC library or someone elses? Are you creating your own? do you just download the (mostly junk) files from vendors (McMaster-Carr, etc.)? Are the files coming in filling out your BOM's correctly? I've done fastener libraries per the correct ASME specs for 2 different companies now, the latest has worked out really well. It's a lot of work, but they work far better than anything else we've tried because they are taylored for our BOM repeat regions. Any thoughts on this? think there's a market for custom fastener libraries taylored to a particular company's needs instead of the typical "one-size-fits-all" fastener library? Thanks!
        • RE: What are you guys doing for library parts?
          ptc-2151062 Bronze
          You can download the PTC standard fastener library (if you have an active account) for free from PTC.com. While that library is by no means extensive, it has been enough to get by on. Included are both standard and metric hardware. I generally modified the most common fasteners to include component interfaces and custom colors. If a required component is not available from the standard part library, I supplement with McMaster-Carr or specific vendors CAD models. As far as drawings go, we do not make a lot of assembly drawings with hardware callouts, so that has not been a great concern of mine. There is a way to add parameters so that part instances will display correctly in drawings, but it's a pain. I think custom part libraries would be helpful, especially if you could easily change the way information is displayed in BOMs. Andri
              Silver
              Hey Andri. Well, I find a lot of the "standard" fasteners from PTC or otherwise to be junk, actually. The geometry does not ever seem to be in accordance with the ASME specs, the thread lengths are usually wrong (if there at all) so you don't know the grip length. No parameters (expected as every company uses different ones for the BOMS). Plus, the last time I looked, the helical lock washers were modeled in the helical (uncompressed) state! What am I gonna do with that? So, for the last 2 places I worked, I convinced them we needed a real library system of fasteners, and made them to conform to the proper specs. On another note, any work down there for an experienced Pro/E guy? I'm trying very hard to get back home to CO to be with my 2 yr-old daughter as I'm just working a tem job in Idaho Falls now.
