We recently upgraded from 4.2 to Arbortext 6.0. We are using our same DTD and FOSI. We had no problems with 4.2 but were losing support so we upgraded. We are having one problem with the undlining of the titles in our subparas. With the 4.2 the underline would stop at the period of the title. In the 6.0 version, the underline does stop at the period on Para0's but all subparas it extends past the period like two more spaces. We need help in finding out a way to fix this.
Hi Vickie,
No way to know without looking at the FOSI. Look into how the underline is applied in the subpara titles. PTC never guarantees fidelity from one version to the next, and there have been a LOT of changes from 4.3 to 6.0. If this is the only problem you've found, you're very lucky.
Liz
