in creo 2 simulation, I simply need some guide to figure out how to apply some preload to some parts before I run the shock or random vibration analysis.
I think I got it. On refine model tab, you need to specidy volume or surface first. then you can select that section and apply your desire load. but I still don't know how to change the direction for it.
Use the following items in the References area to define a general solid type bolt preload:
