MathCad results in Excel
ptc-6639785
Does anybody know if there is is simple way how to assign mathcad result from matrix to excel specified cell. I got formated excel table which I want to fill in certain cells with results. I enclosed the simplified file where is easy to understand which result should go to which cell. Any tip is really appreaciatted. Thanks for help. David
MikeArmstrong
(To:ptc-6639785)
You have to specifiy the input cell. See attached.
7 REPLIES 7
MikeArmstrong
(To:ptc-6639785)
Thanks a lot Mike for answer. Just got back into this task. So you entered starting cell of the excell tabel as first input from mathcad matrix. Am I right? Capture.JPG
MikeArmstrong
(To:ptc-6639785)
Yes. As 'Foundation_Forces_HW_Max_Pull_Load' is a two column four row vector it will pass all those value starting from B4.
Thx a lot for your effort. Best Regards David
MikeArmstrong
(To:ptc-6639785)
No problem at all David. Did you manage to complete your task?
Hello Mike, I did complete it, As well combine several matrixes into one table. It went smooth. Also the result is now converted to kN as original matrix.
MikeArmstrong
(To:ptc-6639785)
Good stuff. Would you mind marking this thread as answered to others know.
