Use text for all context menu entries in Creo 3?
David_M
Edit Definition and Edit References now appear as icons in the model tree context menu. Some other commands also appear this way. Does anyone know if there is an option to change this so that each entry has a text description?
msmith
(To:David_M)
Hi David,
Sorry this was not answered earlier, but this is not possible and is documented in article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS244936 .
Mike
msmith
(To:David_M)
Hi David,
Turns out this is possible. Article CS244936 has been updated.
Mike
