CREO 2.0 ASSEMBY
ssr
CREO 2.0 ASSEMBY
IM A FRESHER IN USING CREO 2.0. PLZ HELP ME OUT OF THIS PROBLEM " I DID PART MODELLING OF SCREWJACK AND NO ISSUE IN THAT.AFTER WHEN I START ASSEMBLING , PROBLEM STARTS LIKE SUPPOSE IF YOU SELECT THE SURACES TO BE COINCIDE , SOON AFTER YOU SELECTING ONE SURFACE THE OTHER PART IN ASSEMBLY DISAPPER WITH LOT OF COLOURED MESSED UP LINES SHOW AROUND IT .WHAT TO DO? NEED SUGGUSTION.
dschenken
(To:ssr)
It looks like a graphics system problem.
To check if the graphics system is a problem add the following to the config.pro file.
graphics win32_gdi
There is a space character between "graphics" and "win32_gdi" when you edit the file directly.
You can edit config.pro directly with Notepad or Wordpad or use the Tools-Options in Creo. This is a link to Help on using configuration options http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/fundamentals/fund_five_sub/About_Configuration_Files.html
You will need to restart Creo for the option to work. If the display is correct with this option, then it is probably a failure in the graphics card support software.
This option bypasses the graphics acceleration of an installed graphics card only for Creo. If you want the graphics card to work correctly for Creo you will need to try a different graphics card driver from the maker of your computer or from the maker of the card.
ssr
(To:dschenken)
thank you so much sir for your interset in answering my my problem
