Flexible Items In Exploded Views
BrettL.
11-Garnet
Hello All,
I am currently using flexibility for components in assemblies manipulating both dimensions and features (suppressed) in the components. Any thoughts on how to remove the flexibility in an exploded view but retain the flexibility in the unexploded view?
For example-- I have a rivet that contains a suppressed feature that mimics the spinning of the head in the assembly. Using flexibility, I resume the feature of the spun head in the assembly to reflect the manufacturing process but in the exploded view, I want to show the rivet without the spun head as the purchased item. This technique could also apply to springs except that a dimension is manipulated instead of a feature.
This was previously done with family tables but I would rather not use that method as it creates a seperate number in our WC system and does not relect properly in the BOM.
Brett
vzak
6-Contributor
(To:BrettL.)
Antonius already mentioned the only possible (for now) way : combined views. I'll just specify what exactly should be done there to eliminate FLEX cuts or so:
- for the spring part, prepare part level simprep that has exaclty same features as master rep (one to one). Call it NO_FLEX
- create top assembly simprep FOR_EXPLODE, and substitute spring component with its part level simprep NO_FLEX
- while FOR_EXPLODE is set, create desired explode state. Call it EXPL_NO_FLEX
- now create new combined state that combines simprep FOR_EXPLODE & explode state EXPL_NO_FLEX. It will snapshot desired combination.
- Vlad
Combined view states can help but you have duplications of the parts. If your BOM has to be accurate to the model, this becomes restrictive.
Assembly level family tables can help by varying the state (part level family tables) but overall, it just becomes a nightmare to manage.
If you go down the combined view road, you will become dependent on the combined views to access your explode states. Nothing wrong with that.
The nice thing is that drawings recognize combined states. once you have it worked out in the assembly, the drawing is a piece of cake.
I find that not thinking this through can really cause some serious regeneration issues in both the model and the drawing.
You can also look at snapshots, although I don't think this will help with state changes.
vzak
6-Contributor
(To:BrettL.)
- Vlad
BrettL.
11-Garnet
(To:vzak)
Thanks Vlad
This is what I needed. I forget to mention that I am using Creo 2.0. I have been searching for this solution for some time. I was missing the step regarding the addition of a part level simprep. Also setting the representation of the component in the assembly level simprep to "user defined" to pick up the part level simp rep was a little tricky but works now.
"user defined" = "Activate a simplified rep from the selected component"
The exploded view looks great with the components in their raw state when coupled with a BOM repeat region.
Brett
