searching parts in assembly
thlavinka
Is there some possibility to search for part in assembly according model parameter?
thanks for help in advance
T.
Is that because the parameter is not a String? Is the parameter a Real or an Integer? Then the Type should be changed to match.
7 REPLIES 7
If the search tool wasn't so cryptic, I would say search tool...
I thing the correct answer -is- search tool...
But don't ask me how to use it for your use case.
I wish I had an intro to using rules for this. I don't see that it can't work.
I've attached a rules schematic, though PTC probably rearranged some of it for Creo.
I think you want to Look for - Component and search for the Attribute where the parameter = the desired value. Since it's an assembly I suspect Look In will also come into play.
Jose_Costa
6-Contributor
(To:thlavinka)
Try this settings:
Jose
Hello Jose,
I have tried to search accordin to your settings and it seems it does not work.
B.R.
T.
Thank you David - it was an integer... T.
Jose should get the credit, I just pointed out the equivalent of a typo.
