Prime 3 plot equal scales
gfraulini
17-Peridot
I'm testing, in this days, the Prime 3 and I see that, in the plot feature, there isn't the possibility to equalize the scales between the axes.
I hope this functionality will be insert in the 3.1 version.
Plotting is one of the most important things that, in my case, an engineer have to do; I think the development team must improve this thing, even thinking that you can already do this in MC 15...
Okay,
You just have to do it by hand, like I said before.
Go to every axis and set the same value for minimum, step and maximum. I belieave is the only way to do on Prime what you want.
Regards, LL
Hello there,
What you mean scale?
You have checked click on axis to select minimum, step and maximum?
Like in picture, you can choose the limit of any axis, ok?
Regards, LL
Hi.
I mean this:
Okay,
Regards, LL
RichardJ
(To:gfraulini)
Just one of so many things that are missing from plots in Prime. If you think 2D plots are limited, wait until you try 3D plots!
