Can Creo 3.0 student edition be installed in my computer?
eletica
Sorry for my poor english
The quick installation guide says students can download and install creo 2.0 from www.ptc.com/appserver/auth/it/esd/academicFree.jsp
but when I open the link, I saw the creo 3.0 download manager.
Now the question is if I can choose the creo 3.0 download manager instead of the creo 2.0 download manager, and use the product code in the installation guide to active the creo 3.0 student editon.
You can not license Creo 3.0 with a Creo 2.0 Product code.
Here is the installation guide for Creo 3.0. The Product code for it is in the document.
http://apps.ptc.com/schools/references/install_creo3_unistudent_standard.pdf
Also if you want to use Creo 2.0 you can download it from the same link as Creo 3.0, but you need to scroll down that page.
Alex
Alex
