According to the Detailed Background, it says our UAV can go up to 1320 lbs. However, when we attended the webinar, they say that it's not recommended for our aircraft to go over 55 lbs, and that we'll need a Private Pilot's License for our aircraft.
Right now, our planned aircraft weighs about 1300 lbs. However, if needed, we can switch back to our smaller design.
What do you guys think? And is it recommended to build such a large aircraft?
That's for you to decide. I'd base the decision off of the productivity and not how close it is to the weight limit.
