I am trying to load Creo 3 on computer for FTC team. M010 installed but with just the basics - no Diagram, NC stuff, etc. Another member downloaded and has the full suite. A third has the "reduced" capability as I have gotten. The license files are much larger 17K vs. 7K. Creo 2 was previously loaded, since uninstalled.
A couple of uninstall and reinstall had the same ending. Now I get an ERROR message when trying to install M010.
M010 was uninstalled, M020 downloaded and attempted to install. At the license step, I get the rotating blue circle and a "Not Responding" message.
Any idea what is going on? The team wants to learn Diagram and Harnessing but can't if licenses aren't there.
Robert W Hahn
Mentor - FTC4605 Beaver Dam Robohackerz
Hello Robert,
As I can get from here, you have a license issue.
I'd advise you to delete the folder C:\ProgramData\PTC\Licensing and try to install again.
If you still get issues, please sens a screenshot with the error to -
Alex
I have a similar issue, the istallation is stuck. My teacher told me to install the school version, signaling our school in order to have the license, by where during the install this is asked ?
Baptiste
Hello Baptiste,
I'd guess that your teacher meant to input the school name in the registration form, under the field School/Institution Name.
Here is the registration link if you didn't already filled it up:
PTC Creo K12 Download Student Edition | PTC
Alex.
