Hallo,
in Creo 2.0 when I assemby flexible part, I need sometimes to set flexibility to a specific dimension that is not related to any feature but to which some other features have to adapt to.
For example, I have a hook to assemble, and this hook is an imported part (downloaded from online CAD database). I want to assembly it by setting its stem length as the (only) flexible dimension.
The stem length is not a feature, as I can only do a stem-cutting feature with Creo "flexible mode" tab, so I would need to command its lenght with a dimension that commands in its turn the cutting.
can I do it without using a sketch?
or also with commanding a parameter?
thanks
