PTC Creo View Control not loading in Internet Explorer 11
amanchenosanche
HI,
I'm trying to load the ActiveX module in Internet Explorer 11 it's working in all Internet Explorer versions from 8 to 10 but with 11 not. Any idea about it?
I'm using Windows 7 SP1 64bit. I see the addon in Internet Explorer's addon list it's activated but it doesn't load anything.
Thanks!
Internet Explorer 11 is not supported until 10.2. I am guessing that you are on 10.1 or earlier.
Hi Brian,
Thanks for your answer, I'm using Version: Creo 3.0 - 10.2.30.38.
IE11 is supported, per PTC, as of Windchill 10.1 M050 and Creo 2.0 M100, on Windows 7 and 8.1 machines.
Ensure that your IE browser is configured to run Windchill in document mode 8, or not all functionality will work as it should.
