Hi all,
Followed the document from PTC https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS162869&posno=1&q=how%20to%20get%20custom%20attributes%20in%20… and getting the below popup when tried to generate report. Please share your insights on this.
Save it and proceed with Step5 in the description above.
