Limit Dimension Display
BenLoosli
23-Emerald II
One of our users is getting newly created limit dimensions on his drawing displayed as 12.250 - 12.253. When I created a new limit dimension, it shows as 12.253 over 12.250, like this:
12.253
12.250
Is that a DTL file setting or a config.pro setting and what is the setting name and proper value?
We only have 1 DTL file and it doesn't load like config.pro where a local one will overwrite a system one.
Creo 2.0 m100
Ben,
Try setting drawing option default_tolerance_display_style as std_iso
Ben,
Does the drawing option in last reply solve your question?
