Offline Test Session Report
nborrerojr.
7-Bedrock
There is a report called "ALM_Offline Test Session - XForms". Is there an updated version of this report available? Maybe one made with HTML5? No browsers seem to support XForms any more.
KaelLizak
(To:nborrerojr.)
Hello Nolin,
Unfortunately, there isn't. There's an RFC to support HTML5 reports: RFC 911716? Unfortunately, there isn't an example of the problem that is trying to be resolved in that RFC as it currently stands.
Are you able to modify the XForms report recipe to turn it into HTML5?
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:nborrerojr.)
Hello Nolin,
Kael
Kind Regards,
Kael Lizak
Kael,
Yes, I can use the XForms report recipe as reference to create an HTML5 report. It won't be all that hard. I just figured I would check to see if this already existed before I took the time to do it myself.
Nolin
