All,
In Creo 2 we taught our users that the fastest way to start using your workspace tied to Creo is to do the following
Open Creo
Select Common Folders tab (located above the model/drawing tree)
Select Workspace
Log into Windchill pop up
...and they are done
In Creo 3 M030
Open Creo
Select Workspace
...and Creo Parametric says (Not Responding)
Does anyone have any suggestions?
Thank you,
Lance
Something definitely changed with Creo 3...
Have you tried using File --> Manage Session --> Server Manager? Maybe see if that performs any better.
The same thing happens using File --> Manage Session --> Server Manager.
I can only log into the embedded browser, select my workspace, and then Activate the workspace from the embedded browser.
Is this just one computer or all of them? Are you on the same physical network as the Windchill server? (Not on a VPN.) Do you have any Anti-Virus software or Firewall software that might be causing problems? (Try disabling both.)
Is the Creo Agent starting? Look in Task Manager and see if you see creoagent.exe listed.
Creo will also gripe if it doesn't start:
I'm doing some VPN testing and disabling the creo agent seems to cause the same type of behavior you're experiencing.
