When i re-open a 2D drawing made in an template with title, date, etc.
It doesn't shows the title, date, etc. anymore
Well sometimes it opens sometimes it doesn't.
If i keep opening it again suddenly it's back.
Someone knows how i can fix this?
Thanks in advance,
Jonathan,
your problem is probably related to drawing format, ie. file with .frm extension.
If you open a drawing, Creo is looking for drawing format used in the drawing. If Creo cannot find it, some items defined in drawing format are not displayed.
Test:
To enable Creo to find drawing format you need to set the following config.pro option:
pro_format_dir PATH_TO_YOUR_FORMAT_DIRECTORY
If you want to check your data, please upload model and drawing using How to upload Creo (or other) files
Martin Hanak
I also see i have two maps from PTC one on C: and one on C:program files
Maybe that also has an influence on my config file and templates
Did Martin's response help resolve your question? If so, please click "Correct Answer" next to the corresponding response. If you resolved this on your own, please post the resolution details and then mark your response as "Correct Answer". Marking "Correct Answer" is a vital component to the efficiency of PTC Community; it not only lets informs users currently helping you with the issue that it has been resolved but it also helps future users when searching for a resolution to this issue.
If your question remains unresolved and you haven't moved on, provide the community with an update post with more detail to help gain traction with helping you.
