Hi All,
Can anyone help me to get display name of a soft type for a document object using API.
Sudeep Pai
Sudeep, you can use below snippet to do so.
TypeIdentifier identifier = TypeIdentifierHelper.getTypeIdentifier("com.syn.customDocSoftType");
try {
String displayName = TypedUtilityServiceHelper.service.getLocalizedTypeName(identifier, Locale.US);
} catch (RemoteException e) {
e.printStackTrace();
Here, com.syn.customDocSoftType is internal name of a soft type in my instance.You need to replace it with an appropriate value from your system.
Let me know if you need more information.
try {
Hello Prabhash,
Do you know how to fetch internal name of soft type from display name?
Harshal
Code is working....... Thanks a lot!!!
