Hi
i made a postprocessor using GPOST for a double turret, double spindle lathe on Creo 1
The most heavy thing was to force user to insert manual commands on sequences to tell wich spindle to use
In Creo 3 i can define a lathe machine with double spindle and simply choose what i want to use from a dropdown menu
Gpost doesn't manage this information
How to simplify user life (and why not... my own life programming GPOST)?
Bye
Osvaldo
There are GPOST FIL samples for adding new commands - see link to downloadable samples in this article CS54723
