I am trying to update relations into repeat region, but it is not happening through toolkit.
I have recorded trail file and found that below portion is required for above mentioned portion:
~ Command `ProCmdDwgTblRepeatRegion` |
#RELATIONS |
!%CPSelect a region. |
~ LButtonArm `main_dlg_cur` `proe_win` 9 217 651 0 1 879 750 1280 1024 123583 |
~ LButtonDisarm `main_dlg_cur` `proe_win` 9 217 651 0 0 879 750 1280 1024 123652 |
@ sel view 0 |
1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 |
0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0 |
@ sel view 2 |
@ sel view 1 |
0.116713 0.000000 0.000000 0.000000 0.116713 0.000000 |
0.000000 0.000000 0.116713 155.466474 410.672442 -223.699394 1.000000 0.000000 0 |
@ stack idx 0 |
@SELECTION 0 0 93 0 0 1.0000000000 4.0000000000 246.8714448237 107.8818259386 0.0000000000 |
~ Update `relation_dlg` `RelText` `/*DFirstRun\n/*SecondRun` |
~ Activate `relation_dlg` `PB_OK` |
#DONE |
Could any one help me to understand above?
Ketan
To update you on the above trail:
@SELECTION 0 0 93 0 0 1.0000000000 - Fix one
4.0000000000 - Specific to table ID
246.8714448237 107.8818259386 0.0000000000 - Screen coordinate of the repeat region where user clicked to select for relation
We would like to understand other lines and know whether above interpretation is correct or not.
Ketan
