is it possible to add automatically a certain symbol in a drawing based upon a parameter is YES or NO?
if parameter HOMOLOGATION is YES then i want a correspondant symbol otherwise no
thanks
You can show or hide things with a drawing program. Not the most intuitive, but it works.
We do something similar with classification stamping on drawings.
You put the sysmbol in a 'safe' location in your drawing template and on a specified layer. The drawing program will enable that layer IF the file paraemeter is set to Yes.
You need to build your own If/Then code within the drawing program and set layers bsed on your own criteria.
