Hi all,
I have plotted a angle of the function Omega(x,q). I want to be able to create highlighted contour lines at any given value. For example, the contour plot typically displays angle values from ~60 to 0 degrees and I want to clearly show the 30 degree line. I may want to show the 32.5 or 4.2 degree or whatever I choose. Is it possible in MathCAD 14? Thanks for any help.
I think it's better to find the contour as a function of distance and angle from the highest point. It's faster, the points are more equally spaced around the contour, and you can draw the contour using a line. I just plotted the 30 contour.
You would have to calculate the contour and add it to the plot as another graph.
How would I go about calculating the contour, since it is a complex curve and undefined at various x and y coordinates?
You could try something like the attached (far from perfect, but its suitability depends on your precise needs).
Alan
Thanks Alan and Richard for your input! Richard, that's a very clever approach that makes perfect sense. I wish I would have thought of that.
Yes, much better Richard.
Alan
