Hi Community
Are there any menu or other command able to move/rotate/resize an object back to the original setup?
I know how to make hidden parts move/rotate/resize along with the non-hidden parts (check mark in the references), but when I've move/rotate/resized an Object and want it to go back to how it was when I imported it, without deleting the recent object and starting over?
I'm using Abrotext IsoDraw 7.3-M040.
Importing drawings from Creo Parametric via Windchill.
BR "The rookie"
Jens Holme Bjørneboe
DFM engineer
Widex
