workflow is not opening properly in windows 7 64 bit machine.. here is the attached workflow.
schavan-2
Hi..
Here we are facing one problem related to workflow. We are not able to open workflow in correct format. Very large view occurs when I open the workflow. Please find attached file for your reference.
Sujata
BenPerry
(To:schavan-2)
Sujata,
Do you have a valid support account, and can you view this article? CS139386.
If the steps in the article don't resolve it, are you using 32-bit browser on the 64-bit machine? Perhaps try using only 32-bit java install. And as always, make sure you're using the proper java version that is supported for your version of Windchill. Refer to the software matricies.
BenPerry
(To:schavan-2)
Sujata,
Hi Ben Perry,
Thank you for your reply. Now its working fine..
Sujata Chavan
