Newbie question: Can you help me get started on multivariate regression analysis?
dberkebile
Suffering as a new MathCad user. Can't seem to get started on a 2 independent variable regression. If I could just see an example sheet, I think I could get moving.
Dean
RichardJ
(To:dberkebile)
RichardJ
(To:dberkebile)
Which version of Mathcad are you using?
What sort of regression do you want to do (linear, polynomial, something else)?
Thanks for answering so quickly. I really am very new at Mathcad.
Mathcad Prime 2.0.
I assume polynomial will get me a good enough result.
Dean
X1X2Y
58.062.0944
5202.5696
5252.8368
5303.0368
5403.5184
5504.616
108.066.3456
10207.7232
10258.4272
10309.1168
104010.616
105012.2864
158.0613.7552
152015.456
152516.8256
153018.4128
154022.3008
155028.4224
208.0623.4992
202025.9152
202527.9904
203030.5088
204036.4704
205045.7856
258.0636.1312
252037.1184
252541.4944
253045.7856
254057.872
255072.5248
RichardJ
(To:dberkebile)
Thanks, RJ. Will work on this tonight. You are the man.
DB
With function:
