Does anyone know how to plot something like this in mathcad?
osamy
Does anyone know how to plot something like the equation in the attachment in mathcad?
9 REPLIES 9
(To:osamy)
Please provide the worksheet, rather than this picture.
With respect to which variable(s) do you want to plot it?
What version of Prime do you use?
Thanks a lot
the file is attached .
I am trying to plot the result of the attached integral . I assumed the constants to be =1
x is defined as variable
I am using mathcad Express prime 3
thanks in advance
StuartBruff
23-Emerald II
(To:osamy)
omnia samy wrote:
Thanks a lot
thanks in advance
Here's a top of the head workaround. One problem is that Ei(n,x) is only available as a symbolic function, and symbolic results won't plot. The workaround is to use the symbolic keyword "float" to force the symbolic processor to numerically evaluate the expression, and then assign this result to a variable for use in the plot.
Stuart
Unfortunately, I'm working in Prime 3.1 (trial) and Prime 3.1 files aren't backward compatible with Prime 3.0, so I've posted an image as well as attaching the worksheet.
from where can I get linspace function ?
StuartBruff
23-Emerald II
(To:osamy)
It's in the Worksheet ... which probably isn't that much use to you if you've only got Prime 3.1 (Can oneinstall the Prime 3.1 Trial concurrently with Prime 3.0 ... that way one could at least look at the worksheets?). So here's a picture of one I made earlier ...
Stuart
sorry, the worksheet isn't attached
StuartBruff
23-Emerald II
(To:osamy)
I meant my previous worksheet - the one with the graph on - and is definitely attached to that.
Stuart
Thanks very much StuartBruff‌ , these information really helped.
But what If I want to integrate y(x) another time with respect to x , and then plot it against (t) ?
I attached the worksheet of what I did .
Thanks in advance
RichardJ
(To:StuartBruff)
No
