Cold Routing Empty Bundles, need MOI's
dbowles
Using WF4.0, I have tried a cold route method a few others have used, for
some notional routes.
Usually I would just route estimated amounts of single wire and pairs for a
notional otherwise read in the diagram
Thought this was an advantage until I wanted to look into Mass Props.
I have routed empty bundles and assigned parameters for thickness and Min
Bend R.
Now I would like to assign a density to the bundle but do not see an
option.
Any Ideas?
Douglas K. Bowles
Advanced Programs
Interconnect and Harness Design
520-794-1856 Office
520-490-9395 Cell
520-446-2756 Pgr
PRIVACY ACT NOTICE: This communication may contain privileged or other
Official information. If you are not the intended recipient or believe
that you have received this communication in error, please reply to the
sender indicating that fact and delete the copy you received. It is a
violation of Federal Law to print, copy, retransmit, disseminate, or
otherwise use this information without prior authorization.
jstone
(To:dbowles)
If I understand you correctly you need the following spool parameters: density & mass_units.
density for wires is a linear densiity
jef
In Reply to Douglas Bowles:
Bend R.
option.
Any Ideas?
Douglas K. Bowles
Advanced Programs
520-794-1856 Office
520-490-9395 Cell
520-446-2756 Pgr
