Hello
I have a little problem with sheet metal module in Creo 2. I want to make rip on a bent edge with 0 thickness so when i would unfold the plate i should get pattern of only 1 line for laser cutting procedure. I need those rips for hand bending as you can see from pictures:
I want to reduce the laser cutting time, so instead of those rectangles (picture3) i want to get pattern of lines (pic1)
To get these lines i had to send those dxf to a friend so he could delete those rectangles and put lines instead. He used some other program to do that.
pic 1 & 2 lines
Dxf with rectangles costs 2x more because of longer cutting time ![]()
And i received this:
pic 3 & 4 rectangles
All those parts can be bent by hand.
I placed a plane on 2 side edges and extrude rectangle shape like seen in next picture:
I can draw lines on drawing or on a sketch but this would take me to much time and its not attached to flat state after doing some changes ![]()
Is there any way to put rip in the middle of this bent edge and make pattern of it ?
Regards Andraz
Use projected curves onto the flat to get the lines to follow the surface bending/unbending.
I think there isn't a way for the software to manage a slot that has no sides. A rip doesn't exist in a real flat pattern, so it doesn't have sides, but the software can't display it that way. I expect that software that appears to do this only does it by adding the location of the rip to the flat pattern as a curve, not a solid feature.
Thanks a lot! Projected curve is good idea.
Have a great day !
