3d rotation of the piece
dspinetti
Hello.
I find myself having to use Creo Parametric 3.0 without the mouse, so i wanted to ask if it is possible to turn the piece on itself using only the laptop's keyboard and pad, I unfortunately did not find any way
tgriffin
(To:dspinetti)
Go to the named views icon in your graphics toolbar and select reorient.  Then set it to dynamic orient and you can rotate about x,y, and z of spin center or h, v, and c of screen center.
There is no way to do the same thing that you do with the mouse wheel?
Unfortunately by train I can not use the mouse, travel everyday and I need to work with the creo
tgriffin
(To:dspinetti)
You can try going to your control panel and checking your mouse button settings.  Some computers without a middle mouse button will let you simulate a middle mouse button by pressing both buttons at once.
Dale_Rosema
(To:dspinetti)
