ACIS SAT Export
jfinkell
ACIS SAT Export
We are not CREO users but working with a supplier who is. We need to receive their models in ACIS .sat format. However, the documentation they provided as far as supported export formats shows ACIS .acs. Can CREO export to .sat format, and/or is .acs and .sat the same? Also, can someone provide screenshot(s) of the export options they have available for ACIS, or better you point me to some publicly available documentation on these options? Thank you in advance.
John,
Creo can export data in ACIS (.sat) format.
John,
Perfect, thanks. FWIW I was basing my question/confusion on the CREO 2.0 document, http://support.ptc.com/WCMS/files/135225/en/creo2_hw_notes.pdf, and in particular the 3D Formats section on pg 6.
