Break dependecy of location
eschinzel
Hi everyone,
someone knows how can I break dependency of locations for a cabling? I have a harness that all locations have dependencies of some parts and I would need to break all dependencies. Actually I am creating a new location by side each one and removing the old ones but I hope there is some easier and fast way to remove dependency.
Thanks all!
fmohr
(To:eschinzel)
Under the Locations drop down menu there is a function called "Convert to Offset".  Here you select the locations you want to convert, click OK, then select a Csys.  Those locations will then be redefined so that their only dependency is to that selected Csys.
This should help you.
Cheers.
fmohr
(To:eschinzel)
Cheers.
