CONNECT DATUM POINTS USING STYLE CURVE
bponnusamy
Hello guys,
I'm new to style tool in Creo. I would like to know how to connect Datum points using curves from style tool I'm not able to take reference from datum points.
I know how to connect points using Datum curve. i can't figure out using style curve. Any help is much appreciated.
Thank you
Babu
use shift to snap your curve to the datumpoints when creating a free form curve in Style feature.
//Tobias
//Tobias
Thanks for solution it worked the curve snaps  when i use shift key.
Is there any other way like normal point can't i take reference of the point so i can select multiple Datum points.
Babu
"Is there any other way like normal point can't i take reference of the point so i can select multiple Datum points."
no, you can´t as far as i know.
//Tobias
