I am modelling a 1939 Kelvin Diesel engine which has a myriad of fuel lines. I intend to use the Piping application and want to create some standard pipe and fitting. The pipe is easy, the fitting not so as there are no standard sizes or libraries that I can find.
Pro/piping parts library availability?
I think these have the same links but not to sure. You need to have a PTC account.
