Can i change A4 layout to A3 layout after inserting general view for part in creo drafting?
pjaguar
Hai everybody,
Currently i am create general view for parts in A4 layout, after inserting some parts general views, space not enough for inserting some parts in it, i am desired to change layout from A4 to A3 is it possible to change it. if yes how to do?
in Creo 2.0:
doubleclick A4 at the bottom of graphic window.
select field containing size, open the list and select requested size
Martin Hanak
StephenW
(To:pjaguar)
On the sheet tab (sheet 1), right click and choose setup (or go to the layout tab and select sheet setup). You can change your sheet size there.
in Creo 2.0:
Martin Hanak
