Change all .prt level appearances at the .asm level
mguethle
7-Bedrock
Hi everyone,
I have a question related to appearances. I know that appearaces assigned at the .prt level carry up to the .asm level. And at the .asm level you can change the appearance of the part while it is in the .asm but you will not change the .prt level appearances. I know you can also clear all appearaces. Here is the question:
Is there a way that I can assign appearances at the .asm level to .prt's?
0 REPLIES 0
