I was wondering if someone could help me with this. I noticed that TT fonts print really nice in Creo View. I'd like to change the default font in my drawing's default text style to a common Windows TT font, but not sure how to do it. I came across a prodiagram.dtl file in my working directory that shows the font options, but I can't change it. Every "browse" or "change" type option is grayed out.
I'm I getting anywhere close to what I need to do?
There should be several .dtl files in the <loadpoint>\Creo 2.0\Common Files\<datecode>\text these can be load for different senarios. I believe that the prodetail.dtl is the default for your drawings. There is a config option in there for font. We have our set to Arial.ttf. You will have to save this into your drawing templates/formats.
! These options control text and line fonts
default_font Arial
A couple of things to mention. First you will need to point to the windows font folder in your config.pro.
pro_font_dir C:\WINDOWS\Fonts
!!!Sets the default font directory (Pro/Engineer will load all
!!!fonts in this directory into the drawing regardless of the
!!!contents of the system and working directories).
Also there is a bug that is fixed in M060 that reverts everything that is not checked as default back to win_font.
https://www.ptc.com/appserver/cs/view/spr.jsp?n=2166926
Hope this helps.
default_font Arial
Hope this helps.
Thanks! That worked great. Although the browse buttons were still grayed out in the .dtl file, I was able to just type the font name in and it worked. Thanks again.
Matt
No problem.
