Converting JPG to DXF?
bridgel
3-Visitor
Our wonderful IT department will not allow us to install any ofthe numerous free tools to do this. Is there any way to import an image into Creo and have it output it as a DXF? I need it in DXF format for my ECAD tool which will not import anything but a DXF.
Thanks.
0 REPLIES 0
