Creo 2.0 - Planes not visible
dzulkiewski
I am new to Creo 2.0, but have been using ProE for several years in my classroom. When I started Creo for the frist time only the top plane is visible. I went to the Model Tree and right clicked on the Front plane to un-hide it. Some times the "un-hide" is grayed out and other times it is not.
How can I set all 3 planes to be visible at all times and not have to go in and change it every time? Why would the option to unhide be grayed out?
I'm not sure I understand what you are discribing, can you post some screen shots to help clarify.
I just found out that my IT department installed Creo Direct and not Parametric. Thanks
I've never looked at Creo Direct, but I imagine that could easily be the source of this problem.
That could explain a lot
Welcome to the forum David!
