This seems like a basic question, but I can no longer delete table rows in my drawings. Columns are easy (RMB > delete). Rows I'm at a loss. Can anyone help me?
To close this community thread on Deleting a table row in a drawing or format
Summary of the exchanges and list of solutions proposed:
RMB few times till the row highlights in cyan... or set the selection filter. Select the row and hit the Delete button from keyboard.
That doesn't work in Creo 4
John,
The table which you are referring is standard table or repeat region table?
It's a repeat region table where I added a row in the wrong location.
I think you should create a case for TS to check this.
I think you have to:
MH
You can also hover the mouse pointer to the right or left of the row for preselection highlight of the row, then select and delete. Directly if in Table tab and by pressing Alt outside of Table tab.
<span;>You can choose FILTERS option in repeat region! In FILTERS option, there is two types: one is BY RULE & other is BY ITEM.
<span;>Now choose BY ITEM, it shows 3 types of FILTER ITEM. By default, it is in EXCLUDE option. Now choose the row you need to delete and click done!
