Creo Data Codes Compatibility
rmuller
6-Contributor
Hi Guys,
I just have a quick question for you. I know there is no backward compatibility in Creo meaning you can not open Creo 3 files in Creo 2 or older. But when it comes to data codes. Can Creo 3 M100 files be open on Creo 3 M060 for example?
Thanks.
StephenW
23-Emerald II
(To:rmuller)
Yes, build codes within the same release are backwards compatible.
There is actually a way to open a Creo 3 model in Creo 2 using GCRI plugin.  SeeGCRI Plugin
StephenW
23-Emerald II
(To:rmuller)
rmuller
6-Contributor
(To:rmuller)
Great news. Thank you very much.
