Good morning,
I would to ask if there is a way which does not permit the modification of parameters by 2d data(eg located in the format "&material"), but only by the 3d model directly into parts or assembly.
From my point of view it's very dangerous to have the possibility to change the "& material" on drawing without to align in the 3d model parameter.
Thank you in advance
I may be mis-understanding your question but when you use the &material parameter, that is the 3d model parameter displaying on the drawing and if you change it in the drawing, you are actually changing it in the model.
Thank you for your prompty replay,
my question is: Is there a method for prevent that the users can force the parameter (i.e. deleting the &material) putting the value directly on 2d data?
many thanks
No, you can't disable editing it as a text field. I can't think of a way to have it just display without the ability to edit.
Ok thank you
