Please can any one send me the default original *.UI file for Creo Parametric 3.0 M040 . which contains the original tools on creo default layout. It will be better if schools tab is added. Also mention steps to set it as default.
Hi Azim,
Is this regarding the Student Edition of Creo Parametric?
Amit
Azim,
As mentioned in an earlier thread Creo Layout Changed (Tools/Tabs) we can not help unless you provide more information.
The creo_parametric_admin_customization.ui and/or creo_parametric_customization.ui files is what you are after.
Not knowing your arrangement, you may want to try the following
Ron
