Just starting to experiment with Creo+.
By doing a "SaveAs" I found where my start in directory is.
The question I have is where/how do I set this?
I am used to it being in the icon that is used to fire off the software, but when clicking on the control center to fire off Creo+, I do not anything like that.
Also, my config.pro is typically in my start directory, but I am not sure where to find it in Creo+.
Is there a way to port over Creo Options over to Creo+ Options for all the setting?
There was a Creo+ icon on the desktop.
Do not start Creo+ from the control center.
