Customize Keyboard Shortcuts Creo View
JR_10680659
5-Regular Member
I have Creo View 9.1. Is it possible to customize keyboard shortcuts in this program? I see the option in Creo 10 to do this, but not in Creo View.
You are correct. Additions can only be made to the Quick Access Toolbar or the Regular Toolbar, but not make a keyboard shortcut.
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
JR_10680659
5-Regular Member
(To:achirila)
It's a really straightforward question... I just want to know if it is possible to make keyboard shortcuts in Creo View 9.1. You can do so in Creo 10 Parametric under the options menu. But no such thing exists in the Creo View 9.1 options menu...
JR_10680659
5-Regular Member
(To:Feature)
Right... So what you're showing is how to do it in Creo 10 Parametric. This doesn't appear in the Creo View 9.1 options menu though...
