Drawing Template Creation / Simp Reps - Why BOM on template only links to Master Rep?
MORECREO
Hello, I have created a drawing template with bom tables pre-set so when I create the drawing, everything is already in place. The issue is, I want it to read a specific simp rep on creation. And right now it seems that "Master" is the only option?
I have already searched for threads about this and found one...
"Creating Assy Dwgs - Is there a way to pre-set the Simplified Rep?"
However, the post is from 2014 and the links to a solution seem broken.
I'm hoping that since that was posted 11 years ago, surely they have come up with a proper way to address this?
Any help is much appreciated. Thank you!
Radovan_DT
(To:MORECREO)
You are right that doesnt happen when selecting from default template. Sadly, I dont see any config option so I guess its creo bug.
Radovan_DT
(To:MORECREO)
When creating drawing after choosing format there is popup window to choose which representation you want to create drawing from.
MORECREO
(To:Radovan_DT)
Thanks for your reply, however that popup your showing happens after you select a "format".
Now create a drawing and select "template", if you get the same result then I'd like to know how.
Radovan_DT
(To:MORECREO)
